RCU Forums - View Single Post - I hope it is not a stupid question.
Old 08-16-2005 | 03:00 PM
RysiuM's Avatar
RysiuM
Default I hope it is not a stupid question.
I've been messing around with weed whacker engines for some time playing with diffeent type of ignition (including glow plug) and diffeent fuels. What I found I got quite nice boost of power running the engine on methanol-gas mixture (and magneto ignition).
So here is the question for MVVS 1.6 gas engine. Can it be run on 48.5% methanol 48.5% gasoline 1.5% Motul oil and 1.5% Castrol racing oil? This fuel worked on Poulan 25cc giving about 1/3 hp more still using the same carb (fuel consumption is a bit higher tho).
Will it work or the head will blow off?
RysiuM
