RCU Forums - View Single Post - DDust pulling hard to the right.
Old 08-16-2005 | 08:41 PM
RC-Captain's Avatar
RC-Captain
Default DDust pulling hard to the right.
I could probably experiment from now until the end of time to correct this problem but I am hoping someone experienced this with the DDust or a similar plane and knew how to fix the excessive yaw. If that is what it is called.
my set up is simple : Mag .28 engine
DDust measurements are 16 length x 28 width.
prop is a master airscrew 9x6
I have wheels on the front with the toe in factor which does absolutely nothing for
the ddust.
the all up weight is 2lbs 2 oz.
My first guess to solve the problem would be to use a smaller prop.
Thanks for all replies.
