RCU Forums - View Single Post - New to Li-Po's
Old 08-17-2005 | 04:40 PM
RC Extreme power's Avatar
RC Extreme power
My Feedback: (24)
Default RE: New to Li-Po's
If you run them at 3600 mAh the max I would run static is 28 amps 30 max, They will burst higher than this but you will cut the number of cycles that you will get out of them.
I run two 3S 4P 8800 mAh to be a 6S 4P and pull 60 amps static and when I fly the average amp draw is about 30 amps.
Milton
