Threadlock
It's almost a law- all prop nuts used to hold the fan/clutch assembly MUST be tightened down with RED threadlocking compound (Loctite).....if you flood the engine with a locknut that was not threadlocked- it will almost always unscrew itself- and result in the problem you are experiencing- RED Loctite should do the trick.
Good luck.
