Get rid of those battery connectors....actually if it were mine there would be some GP1100's in there, with actual battery bars, not tin spot-welded across the batts. Brushless motors need as much power as they can get, your batteries and connectors are it's biggest weak spot right now. Make all wires as short as they can possibly be! Resistance=more heat=less efficiency=less speed.
Good luck, let's see some vids!
Bryan
ORIGINAL: u8at711
any Ideas to make this better, ? ? ?
last time I was on the water, It was being called a cerial box prize, Well I hope next time I will rooost there Nitros into submission.
