G-62 Question...
Ch ignition supplies a new prop hub and does away with the flywheel plus you get to remove the spring and its components.
Check them out online and you will see what they supplywith the upgrade.
Of course you add back the weight of the ignition module and battery pack.
I dont have one but the Jump star option looks good as it does away with the spring assembly and you only connect it when starting.
