RCU Forums - View Single Post - Phoenix Funstar 3D .40 HELP!
Old 08-19-2005 | 10:24 AM
SaCCaL72
Default Phoenix Funstar 3D .40 HELP!
I just got a Phoenix Funstar 3D .40 and I am having some instruction manual problems. The instructions are not that thorough and I am a little confused on some things. First off, They give 4 nylon screws to screw down the wing but only 2 holes are in the wing and it seems to me that the wood that you screw down on on the wing is only balsa and could break through if some stress is put on it. Second, there are 2 extra pieces of balsa wood (4"L x 1" W x 1/8th Thick) which they do not explain anywhere in the manual what to do with along with 4 pieces of triangle cut balsa (3/8" x 1"L). Third, the rudder horn, when mounted, is lower than the fuse not allowing a full pull on the rudder. If the horn is correctly placed (holes lined up with rudder hinge joint) the horn will hit the fuse. Does anyone have any ideas what I am talking about and could offer some assistance... Thanks for your help in advance...
