RE: Phoenix Funstar 3D .40 HELP!
THANK YOU FOR YOUR HELP!!! It defiantly eases the mind some. I thought maybe I was going crazy or something, like I was missing something in the manual. (P-40LUVR) I did end up installing the rudder horn just as you did, I feel better now that you did the same thing and it works for you. I was previously thinking of using the extra balsa wood where the wing bolts screw down on the wing to add some strength, but I guess I will see what happens when I get to the throttle area, I may use it as (tIANci) did. I did see in the manual not to full throttle the plane as it may break up, that is too weird. This is my first 3D Plane and I am not used to that, used to flying fast and hot doggin', something I have to watch, thanks for the warning. The plane all-in-all looks great and was packaged VERY well in the box. Everything seems pretty sturdy. I can't wait to get it all done and fly, waiting for my O.S. 50SX to come in to install into it. What engine did you guys go with? Any flight characteristics I need to watch for? Again, THANKS!
