RCU Forums - View Single Post - TF GS p-47 problem
Old 08-20-2005 | 07:51 PM
timothy thompson
Default TF GS p-47 problem
Ok Here goes. I have a G-45 up front run 20 X 10 prop weight 24lbs. Balanced at rib 5 5.25 from le. On T/O need full down trim on elev and she takes off perfectly no rudder correction needed. and she flys nice too.
Problem landings!! If I keep the trim down I run out of elev and we break props and bend gear! We dont want to do that so I tried on the downwind side as soon as I drop the gear to go to full up trim and imm. drop the flaps. Plane lands fine this way. I have never had to change trim settings on the .60 bolt so whats wrong?
