RE: Duratrax Nito Evader ST Stripped Differential, what else should I order?
Get a set of front suspension arms, rear suspension arms a front shock tower and a rear shock tower, and a spur gear, then if you break a part you can replace it and send in the broken one for warranty. Also i would get a set of steering knuckles, and a set of rear hubs. That should keep you running for a long time.
