RCU Forums - View Single Post - Help !!! How to pull off the drive washer?
Old 08-21-2005 | 05:22 PM
William Robison
Default RE: Help !!! How to pull off the drive washer?
Pe:
The locking taper ( 10 degree ) was a deliberate choice on the four stroke engines, it gives that added bit of prevention against throwing a prop. On a two stroke engine with its lower tendency to backfire the non-locking tapers of 17 or more degrees angle are fine.
With my puller I've never had to use any heat - you may have noticed it's rated at 5000 pounds screw pressure - but it is a lot more money than could be justified for casual use.
Bill.
