RCU Forums - View Single Post - Trouble getting engine tuned?
Old 08-22-2005 | 04:11 PM
bruce88123
Default RE: Trouble getting engine tuned?
If the high speed needle is screwed all of the way in, you should be extremely lean at high end and the engine SHOULD die. Open the high speed needle about 1-1/2 to 2 turns and see what happens there. Open the carb slowly at first until you get the tune closer to correct.
BTW - yes, that description make a lot more sense. KLUTZ! Sorry, had to throw that in.
