RE: Throttle and Steering Servos twitching
check all your wires on the servos & battery leads, you may have nicked one & if it rubs up against metal it will twitch. also check for kinks. and make sure the crystal in the RX is in properly. you can fix nicked wires by putting some heat shrink over them if they aren't too bad, or solder them & then heat shrink them.
