Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Nitro Stadium Trucks
 Throttle and Steering Servos twitching >
RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Old 08-22-2005 | 06:30 PM
Default Throttle and Steering Servos twitching
how ya doin i have a jato and just recently crashed it, ruined the whole front end, i got a futuba high torque servo for the steering now when its off the servos both twitch slightly. When i'm holding the truck vertically is does the same thing...when put horizontal it stops... then if you let it sit for a little kicks in again? What did i do? What do i have to do? Thanks in advance
Old 08-22-2005 | 06:51 PM
dicko's Avatar
Default RE: Throttle and Steering Servos twitching
check all your wires on the servos & battery leads, you may have nicked one & if it rubs up against metal it will twitch. also check for kinks. and make sure the crystal in the RX is in properly. you can fix nicked wires by putting some heat shrink over them if they aren't too bad, or solder them & then heat shrink them.
