RE: TF GS p-47 problem
Must be a TF thing as my Vailly does not have any weird vices. Very straight forward flyer.
I use the steep approach only in windy conditions with 1/2 flap setting. This allows this plane to penetrate any threshold turbulence. I do keep a bit of power on though, once over the threshold I cut back to a click above idle and let the flaps do their job till touchdown. regular non windy days it's 3/4 flap, shallow glide path and throttle it in.
I have never experienced any elevator blanking on this plane, but that's not to say the TF doesn't suffer from it.
Is the down trim at high speeds a TF P-47 characteristic ?
My Vailly hardly changes pitch at all, even when the flaps come down. My wingloading is probably higher which would explain that.
S1
