RE: Vector Flight Xtra 300 66" build
I used Hitec 425's for throttle and ailerons. Used the 475's for rudder and elevator. I would suggest the slightly stronger servos for at least the rudder. There is very little throw on the elevator so if you set it up with full servo travel, you will get a great mechanical advantage. I suspect that the 425 would be perfectly adequate for the elevator.
Ross
