RE: Another Way to Solve the Backpressure Issue!
Hey guys,
Sorry the computer was taken last night when we got home! I'm loving this thing on my engine! VERY constant fuel ndraw.. I too had thougt there would be no way to keep her running but after leaning it out it runs AWEOME!
Joe,
If you get a check Valve.. Put it on as I have described, tune up your engine, let it run a min or two. then cut it off and quicly pull the carb line off you will see that fuel will come out constantly for several seconds.. SO when you pull into a hover.. the mixture remains the same regaurdless of the inlet pressure. I think that answers your ? [&:]
Anyways,
I'm really happy with my set-up and it's alot easier than setting up a reg. or pump... Richard, Try it out and see if you get the same results
