ORIGINAL: Gerald Rutten
[snip]
As I mentioned before, most (If not all) turbine brand ECU“s have this function also incorporated.
Regards,
Gerald
You're the second guy to mention that, but the problem is, if the ECU is still getting pulses, even though they may be erratic from a PPM glitching episode, the turbine will continue to run. I know of no ECU that will monitor the incoming pulses and filter them like an IPD receiver will, so the only way to get reliable shutdown on loss-of-signal is to use PCM.
BTW, the point still stands that if you truly had a PCM failsafe due to interference, then the aircraft would have been unflyable with PPM as well. I would suspect that most of the crashes that guys attribute to PCM "lockout" are really, either battery failure, switch failure, servo failure, or RX crystal failure...
Bob
