RE: Dual Ailerons and Elevator
You need "elevon mixing". Check the radio manual to see if it does "elevons". If it does, enable it, and you're all set. If it doesn't, then there are add-on mixer boxes that you can plug in between your Receiver and servos that will do the job.
