I dont why yours would end up on the cover if you set the step on the CG, mine turned out ok unless your CG was not at the right place.
I find 3" to be a bit much,I always try not to exceed 1 in front or back, but the incidence is very important.
Got mine flying on floats at 20 lbs and take offs with 50% flaps and landing with 100% flaps, it flys very well.
ORIGINAL: MORROMAXX
Good Afternoon, I´ve been reading these posts regarding the incidence of the wing and I will fix the issue soon, but my trouble is with the step of the float, which is 3 inches behind the CG and if I move it forward it would end up on top of the cover of the float. What should I do, just leave it and fix the incidence problem? Thanks for any help I can get.
Sincerely,
Morromaxx
