RCU Forums - View Single Post - MUST-KNOW THINGS for owners of a Genesis LIMITED EDITION (not previous versions)
Old 08-27-2005 | 01:48 PM
jigga2177
Default RE: MUST-KNOW THINGS for owners of a Genesis LIMITED EDITION (not previous versions)
Ok...am I the only person here that noticed there really is no hugh difference between the latest standard Genesis and the Limited Edition model? Besides the body and the transmitter.....if you go to cenracing.com, and click the specs link for the LE Genesis, it takes you to the page for the standard Genesis.
Things to look out for....Because they are the same on both trucks....
1) Servo's on my Genesis were bad when I recieved the truck. Might want to replace them.
2) For me the engine was hard to start, just the way it is when breaking it in.
3) Roto-start is great, but will eventually break one-way hub.
4) Brakes....stopping this truck will be very challenging to say the least.
That's about all the trouble I had with the truck so far. You may want to go through it and lock-tight everything that's looks like vibrations could back the screws out. Also, pay close attention to the line about the servo's...the servo that came with mine ended up destroying the gears in the transmission because it was shot. Cen racing replaced it for free, so I'm not too upset about it.
