RCU Forums - View Single Post - BME CAP Maniac
Old 08-27-2005 | 04:10 PM
  #301
drumbum's Avatar
drumbum
Default RE: BME CAP Maniac
well i cut my wing open and all i can say is good grief[:-] there was no glue on most of the ribs. all of them to the servo are exploded. even the one that was rigged because someone in the factory broke the "foam" strength balsa rib and attempted to glue a doubler in there which is also broke and glued with a 1/8 gap. the only thing holding it was a glue gob.. the trailing edge "soft balsa" is broke. the top sheeting was broke. there was no glue on the farthest rib that makes the cutout for the wing saddle.. so basicly the only thing holding the wing together is the main spar and the bottom sheeting i cut off.. even the streamers were soft balsa.. i wouldnt trust this wing in a harrier much less a blender.. I chalk this up with all the other problems i had with this plane as another stab in the rear by BME.. I also have a lesson learned with this PILE.. its a shame too because the plane actually flies good. so they get a 10 on that a goose egg on everything else....
i will post pic when i get time...[:@][:@][:@]
