Pete is right, these suckers are like minature grass sweepers. And if you don't check it, it will end up in the tail section. So if you fly off of freshly cut grass, shake the grass out after each flight. My Herk does the same thing.
How about a servo controlled rear ramp? Then do a flyby and drop the grass clippings back on the field like a Fire Tanker dropping slurry.
