RCU Forums - View Single Post - Vector Flight Xtra 300 66" build
Old 08-28-2005 | 07:05 AM
  #48
suitcase's Avatar
suitcase
Default RE: Vector Flight Xtra 300 66" build
Thanks Grelker, I'll look into using your method. Did you make the piece of ply run up on the curved surface at all or just keep it flat? Did you use the existing blind nuts or change the size?
What size do you drill wood to tap for 1/4 20 bolts? How thick should the wood be to hold? In steel, the nut is basicly the size of the bolt thickness.
