RE: after swashplate leveling, CP2 wont lift
when you lengthened the elevator rod, you caused the swashplate to sit higher on the main shaft, to keep the same pitch you would of had to lengthen the elevator servo alittle and shorten the other two servo rods. So basically now what you should do is shorten all 3 rods equal amount of turns until your satisfied with the results.
