RCU Forums - View Single Post - Hanger 9 Extra 330l Comments Positive and negitive
Old 10-28-2002 | 12:53 AM
dirtybird
Default Re: 330L
Originally posted by bodymann
dirtybird i just bought this plane it will be my first gas plane & 33% also i plan to use the same motor that you have how was the instaltion of the motor any tricks or just straight forward.
any more info would be apperiacted
btw what is static balance & how is it done.
is there a new wing verson read it some where else.
thanks dennis
You will need to fabricate standoffs to mount the motor ahead of the provided mounting box. You will also have to cut a clearance hole in the mounting box to clear the carb. I side mounted mine. It leaves the right side of the cowl empty.
Static balance of the ailerons is putting a 2 oz wt 4" ahead of the aileron hinge line on a rod that is connected to the aileron on the tip of the wing
