Hanger 9 Extra 330l Comments Positive and negitive >
Old 10-25-2002 | 02:43 PM
Default Hanger 9 Extra 330l Comments Positive and negitive
I have a chance to get a good deal on this plane and I want to know anything good or bad about the plane. The plane in question is the two servo wing and is NIB. I plan to use a ZDZ 80 single and need to know if I will have to add a lot of nose weight like I did for my Sukhoi. How well will this Bird 3D with a zdz 80 on it? Can this plane come in at 24 to 25lbs? Any comments would be appreciated. I would like to hear all positive or negitive comments. Thanks
Old 10-26-2002 | 06:11 PM
DENNIS C's Avatar
My Feedback: (99)
Default hanger 9 330 l
just bought one today wish i could help. i would also like to hear what they have to say.
thanks dennis
Old 10-27-2002 | 05:41 PM
Default 330L
I have the airplane with the ZDZ 80.
I am not a 3D pilot so I can't help you there.
Throw the landing gear away and get something else. It has been formed over a sharp edge and will break at the slightest overload.
Back up the servo mounting areas. 1/8 lite ply is just not adaquate to hold servos with sheet metal screws.
Put a dowel in the forward aluminum stab tube to prevent it from coming out and having the stab rotate.
I think the ailerons should be static balanced even with two servo's per aileron.
Mine weighed 25#
I put both ignition and receiver batteries just behind the firewall and did not have to add nose wt.
Old 10-27-2002 | 06:53 PM
DENNIS C's Avatar
My Feedback: (99)
Default 330L
dirtybird i just bought this plane it will be my first gas plane & 33% also i plan to use the same motor that you have how was the instaltion of the motor any tricks or just straight forward.
any more info would be apperiacted
btw what is static balance & how is it done.
is there a new wing verson read it some where else.
thanks dennis
Old 10-27-2002 | 07:15 PM
Banned
My Feedback: (788)
Default With a GT80
It needed a roll of pennies in nose weight
Old 10-27-2002 | 11:25 PM
My Feedback: (19)
I have one with a Brison 6.4 in it. Pretty much stock. I lightened the airlerons and recovered them and use the Single servo version. I have JR 8411s with the little output shaft reinforcements.
The stock gear is cr*p. Go buy the TNT gear. With the Brison, my weighs in a 27lbs with the batteries all up front. It's a little nose heavy for radical 3d, this way, but it flies very nice.
If you can built it with the ZDZ and keep things balanced without extra weight, you will have nice flying plane. I have the Cap and ZDZ ready to go on the bench, but I'm having a good time with the Extra now that I got all the gremlins out.
Regards,
Lee
Old 10-28-2002 | 12:53 AM
Default Re: 330L
thanks dennis
You will need to fabricate standoffs to mount the motor ahead of the provided mounting box. You will also have to cut a clearance hole in the mounting box to clear the carb. I side mounted mine. It leaves the right side of the cowl empty.
Static balance of the ailerons is putting a 2 oz wt 4" ahead of the aileron hinge line on a rod that is connected to the aileron on the tip of the wing
Old 10-28-2002 | 05:42 PM
DENNIS C's Avatar
My Feedback: (99)
Default 330L
DIRTYBIRD THANKS
