RCU Forums - View Single Post - Will my setup work ? (flatanta)
Old 08-30-2005 | 11:58 PM
whoover619
Default RE: Will my setup work ? (flatanta)
That engine you mentioned is too big for the flatout, you need something more like the Axi 2204 or mabey the Axi 2208 (Good for outdoor) with the Jeti 4 amp or 18 amp with 2208 considering the flatana is 7.5-9.0oz depending on how well you build it, the flatana is a flat light weight plane.
Why are you getting 4 servos, it requires 3 (rudder, elevator, and aileron) the 4th channel is the engine which is controlled by an electronic speed controller. I would get 3 HS-55 servos.
If I were you I would get the GWS 4 channel Pico Reciever Vertical Pin but order Futaba or JR depending on your radio but if you do get the GWS UM-1 crystal on your frequency on your radio.
Get a 3 cell Li-Po like the electrifly 11.1v 640Mah Li-Po battery or whatever.
Here is my setup and it works excellent, I love it but it can be pricey.
3 hitec HS-55
BL-8 Brushless Electronic Speed Controller
Brushless Rimfire
Electrifly 11.1v 640Mah Li-Po
GWS Pico 4 channel JR Vertical Pen Reciever
Channel 37 GWS UM-1 Crystal
9X3.8 APC SlowFly Prop (If you dont want to but a prop the stock one works great too)
