Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 Will my setup work ? (flatanta) >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 08-30-2005 | 10:41 PM
Default Will my setup work ? (flatanta)
hey
I was wondering if my setup will work before i buy a flatana 3d?
m o t o r : axi 2212/26
speed control: Jetti 18 amp
r e c i e v e r : hitec micro555
s e r v o s : two hs-55's and two hs-50's
b a t t e r y : 1500 2cell li-po
i just dont want to spend another hundred and fifty dollars to get it flying
Old 08-30-2005 | 11:58 PM
Default RE: Will my setup work ? (flatanta)
That engine you mentioned is too big for the flatout, you need something more like the Axi 2204 or mabey the Axi 2208 (Good for outdoor) with the Jeti 4 amp or 18 amp with 2208 considering the flatana is 7.5-9.0oz depending on how well you build it, the flatana is a flat light weight plane.
Why are you getting 4 servos, it requires 3 (rudder, elevator, and aileron) the 4th channel is the engine which is controlled by an electronic speed controller. I would get 3 HS-55 servos.
If I were you I would get the GWS 4 channel Pico Reciever Vertical Pin but order Futaba or JR depending on your radio but if you do get the GWS UM-1 crystal on your frequency on your radio.
Get a 3 cell Li-Po like the electrifly 11.1v 640Mah Li-Po battery or whatever.
Here is my setup and it works excellent, I love it but it can be pricey.
3 hitec HS-55
BL-8 Brushless Electronic Speed Controller
Brushless Rimfire
Electrifly 11.1v 640Mah Li-Po
GWS Pico 4 channel JR Vertical Pen Reciever
Channel 37 GWS UM-1 Crystal
9X3.8 APC SlowFly Prop (If you dont want to but a prop the stock one works great too)
Old 08-31-2005 | 08:56 AM
i have four micro servos already
and i dont really feel like getting a new reciever
so alll i really need to change is a motor/esc and the battery?
Old 08-31-2005 | 09:05 AM
exeter_acres's Avatar
foamies need to be light to fly well.....
smaller motor, esc, battery and Rx if you can.... think of it this way....
1 oz difference may not sound like much but that can be 10% or more of the weight of the plane.... a 10% weight savings is a Huge amount......
so often I hear people complain about a plane only to find out that the setup is all wrong for the application....
Old 08-31-2005 | 09:11 AM
so how much will a new motor/ecs and an rx cost me?
Old 08-31-2005 | 09:39 AM
GWS rx (I have never had a problem with mine)
about $25
motor...depends on what you end up with....
$30 to $70..
I like my Axi 2208/34, but there are other out there...
Esc
http://www.towerhobbies.com/products.../gpmm2070.html
$35 or so...
I use CC but have not heard anything bad about the BL-8
battery
I use the Electrifly mentioned above on my foamie with VPP and it works well
http://towerhobbies.com/products/gre...gpmp0800m.html
about $40
Hope that helps
Old 08-31-2005 | 09:48 AM
what battery should i buy, will this one work
its the third one up from the bottom 1250 mAh 11.1 2cell
Old 08-31-2005 | 10:01 AM
that still seems awfully big, I would get a smaller 3 cell for more power...and an ounce less weight
I use the 640 mAh 3cell pack....
Old 08-31-2005 | 10:07 AM
why cant i get a 2 cell 11.1volt 720mAh li-po its alot lighter
Old 08-31-2005 | 10:15 AM
I've just never been a fan of 2 cell setups....plus I fly outside.....\
I like the extra power of the 3 cell......
either way would work
Old 08-31-2005 | 09:55 PM
I used to fly 2 cells on everything and then I started flying 3 cells in my shockflyer and haven't gone back
Old 08-31-2005 | 10:32 PM
hmmmmmmmm...
Old 09-01-2005 | 07:26 AM
I guess if you are looking for longer, mellow flights, the 2 cell pack is perfect....
more power, unlimited vertical, punch out of hovers, etc. etc. but slightly shorter fkights, then it is 3 cell....
Like I mentioned, I use 3 cell....
Old 09-01-2005 | 10:16 AM
thank you for the advice i will be buing a 3 cell 640mAh 11.1v
Old 09-01-2005 | 09:43 PM
What is wrong with the stock motor? I am using a 720 ma 3 cell pack with hs55's, a gws receiver and a 20 amp speed control that came with the nicer dean style plugs. It has all the ump I need with the 3 cell. I wouldnt get a new motor if it where me(and I didnt lol) and just get the receiver and 3 cell pack and go fly.
Old 09-02-2005 | 03:41 PM
I'm running on the stock motor in a GWS 6.33:1 gearbox with a 1260 prop, and it's got a ton of thrust (hovers at about 1/3-3/8 throttle) and stays cool. I've got a Polyquest 3S 850 pack and a GWS ICS-300Li ESC. Couldn't ask for a better plane or setup.
Old 09-02-2005 | 04:18 PM
less money to spend great
