RCU Forums - View Single Post - Building a Laser3D
Old 10-27-2002 | 04:41 AM
radfly
Default Building a Laser3D
BTM, I wasn't trying to diss you, man. I do not attempt harrier landings, well, that often that is. I have had two power-off landing that turned into that. But, the plane took it ok. I did have to straighten the tail gear when it did.
I am by no means a pro, and keep my flying at least two mistakes high. And with this plane at 3D rates and no tip stall tendancy, that is about 20 feet high.
I agree the elevator could be hosed with a hard contact with the ground, and if you are into that sort of thing, definately reinforce it with CF or sheeting.
This plane could easily suffor an additional 6 oz of strenthing for reinforcement, without a noticable flight performance hit.
