RCU Forums - View Single Post - Building a Laser3D
Old 11-01-2002 | 12:38 PM
  #41
mike98624
Default Building a Laser3D
hey guys,
still no kit defects, but a semi-major builder defect (i'l get to that in a moment).
so i the trailing edge joined (easy), put on the rear sheeting (easy),and then i got around to doing the front sheeting (cringe). I put on the top left piece first, and had a little defect where the wwood popped along the leading edge a bit. on the right side, this happened again, except a lot worse, and out towards the end. My remedy for the messed up top sect.s is to put filler underneath the sheeting, and then sand through all the defects when the time comes. I still need to think up a better method than what i've been using. suggestions PLEEZ!
