RCU Forums - View Single Post - Building a Laser3D
Old 11-02-2002 | 03:37 AM
  #43
BTM
Default Building a Laser3D
Combat 20,
Good idea using the spruce!
I replaced the goofy wing hold down setup with a Dubro 1/4-20
setup which was very similar to the kit pieces.
Crazy Mike,
I full length tack the sheeting to the leading edge with thin CA, then I wet the sheeting with windex, form it to the contour till it holds the shape.
I then use Slow CA on the ribs, press the sheeting down with a large straight edge until the glue holds, and then grab a beer.
