I was just pointing this out, of course this is not a beginner airplane either, I have been flying RC for about 17 years, so I have built a few models before, arf did not really exist then.....
I find that for a laser kit the fit is rather loose in the balsa but good on the ply pieces, my wing took me about 5 hrs to plan and put together, the sanding is the only thing left....and I won't do it until almost ready to cover.
I have built the wing tip on mime.....I can always remove them later
I have been looking at the engine mount, and using my gram scale the wood mount is about half weight compare to commercial plastic mount, so I'm going to used this wood mount if it doesn't work I will just cut it of and use my long plastic mount.
I have took a few digital, I will post them tonight.
Daniel D.
