Building a Laser3D
I'm using the stock mount on mine, and it's just fine! This is one of those places where you can add a lot of weight if you aren't careful. I used 30 minute epoxy to glue the mount together so it could soak into the wood a bit, but I was careful with the amount I used. No WAY would I add something as heavy as one of those Du-Bro mounts, they're the biggest waste of weight I've ever seen. The stock mount is just fine, but it does require fuel proofing once it's done. A little clear dope works well here, or if in a pinch, epoxy finishing resin thinned with alcohol will also work at the cost of a bit more weight.
