RCU Forums - View Single Post - Building a Laser3D
Old 02-12-2003 | 03:43 AM
  #169
R/CDragonfly-RCU
Default Building a Laser3D
Reid,
Did you wind up sheeting the back half of the fuse?
I just got my kit today and plan to modify it a bit.
Sukoi nut did you lengthen the elevators spanwise or chordwise?
Same for the rudder? Was that mod suggested by anyone?
I've been thinking that the counterbalance part of the elevator looks too long spanwise. Of coarse I'll strengthen it but might it benefit from foiling also?
The fuse side area is much smaller than the flip and has little area under the wing. I'm thinking of adding a built up stringered cage full length under the flat fuse bottom. Might some forward side area disguised as wheel strut cheeks improve knife edge maneuvers and flat spins?
Can the Laser 3D flat spin as well as the pizzaz I saw climbing in a whirlwind inverted flat spin last week?
