I HAVE a lanier stinger 60 arf on the way ( traded my 91fxs for it ) ...when it gets here is there any thing I should change or beef up on this arf??????? WILL use SAITO 100 for power......should I side mount the motor....did you use stock muffler....any one with pics of saito in plane?????
ON other treads I read plane will come out very nose heavy....is this true????? HOW much tail weight did you have to add????? I realy did not whant to have to rebuild tail of plane to take servos.......if I whanted to build I would have orderd the KIT?????
IS the landing gear strong?????? if not what should I replace it with??
WHat is the covering ?? MONOKOTE or ULTRACOTE???
and what colours match
THIS looks like a very good plane
HOPFULLY as good as the kit I had years ago
dose the ARF fly as good as the KIT it was great>>>>>
thanks for your help
