Lanier Stinger 60 Arf >
Old 10-25-2002 | 09:05 PM
Default Lanier Stinger 60 Arf
I HAVE a lanier stinger 60 arf on the way ( traded my 91fxs for it ) ...when it gets here is there any thing I should change or beef up on this arf??????? WILL use SAITO 100 for power......should I side mount the motor....did you use stock muffler....any one with pics of saito in plane?????
ON other treads I read plane will come out very nose heavy....is this true????? HOW much tail weight did you have to add????? I realy did not whant to have to rebuild tail of plane to take servos.......if I whanted to build I would have orderd the KIT?????
IS the landing gear strong?????? if not what should I replace it with??
WHat is the covering ?? MONOKOTE or ULTRACOTE???
and what colours match
THIS looks like a very good plane HOPFULLY as good as the kit I had years ago
dose the ARF fly as good as the KIT it was great>>>>>
thanks for your help
Old 10-27-2002 | 01:48 PM
My Feedback: (12)
Default Been done already
Check this thread....
http://www.rcuniverse.com/showthread...hreadid=223084
Covering is Ultracote, Flame Red (883) and either Deep Blue (873) or Midnight Blue (875), I can't remember which.
LG is PLENTY strong. D
Old 10-27-2002 | 06:41 PM
Default Stinger 60's
The OS FX 91 is a perfect motor for your stinger. I have the kit and ARF stinger and both took app. 4 oz. in the rear to balance out with the OS setup.On my second build job I installed 2 -1/4 wide hard wood braces from the firewall to the servo tray in the floor for braceing and it seems to work good and definitely made the plane stronger where it was weak.
