If you have an amperemeter it is enough for check of setups. Also, as mentioned you can get a lot of flying just by following the recommandations given by the motor-manufactors, on forums and read tests done properly.
As an addict gadgetman I have the E-Meter from Hyperion... Built in RPM-counter and the ability to put in prop-constants to get thrustreading is a hit
