ORIGINAL: tf2psycho
you will be happy with that POWERFULL inrunner as long as the mesh is perfect
i use a plastic parts bag to set my mesh ..and over 100 flights on the yak54f with no stripping of anykind ...its all in the gearmesh &....prop choice along with the batt and servo weight ...are important also throw(extended servo arms) !!!!![:@]
a little tip for ya...toss the stock gearbox and get a himaxx aluminum gear box...they are only like 25 bucks and you dont have to mess with the gear mesh, and the gears are a helluva lot easier to change and IMHO alot easier to find at local hobby shops.
just my.02 cents
ORIGINAL: rcMitch71
Could you put a glow engine in this? I saw a mini funtana with a O.S. .15 and wondered if it would work in the edge.
im assuming you can, but i have read that the funtana with the 15 in it was even more of a pig off power than the stock set up, so who knows how the edge will do....
