RCU Forums - View Single Post - PPM, PCM ?
Thread: PPM, PCM ?
Old 09-01-2005 | 05:54 PM
  #70
specialFX's Avatar
specialFX
Default RE: PPM, PCM ?
ORIGINAL: robert
ORIGINAL: rpmtech
Like what was said, PCM can and will HIDE a potential problem, and it will rear it's head at the most unfortunate time.
So how do we make sure that a PCM receiver is not hiding a problem? I've heard several times that you can do all the checks with PPM and when everything is ok change to PCM. However I find that most of my incidents come from messing with my models by changing stuff around that was just fine to begin with.
The most easy way to be sure PCM doesn´t spoil your results is NO TO USE PCM;-)
Don´t be fooled, up to now I use PCM, but I think some other solutions are on the horizon!
Thomas
