RE: CG Matrix, a tip-stalling machine??? Help.
Double check your throws. Your throws have to be high enough to force the plane through the snap. Lateral balance may be part of the problem, but there is a point where not enough throw will cause a snap and more will get you through that point to where the plane is completely stalled. The danger zone is usually some where between 25 and 35 degrees. Make sure that you are getting a min of 40 degrees of deflection.
