RCU Forums - View Single Post - Kyosho Cap 232 40
Old 10-27-2002 | 01:11 PM
Joe B.
Default Kyosho Cap 232 40
Since you found the problem, I wouldn't worry about the engine to prop hub location like I mentioned earlier. That was my first thought since I had thee xact same setup and it balanced correctly. Now that you've found the culprit, check the balance again and I'm sure it'll be fine.
