5995tg programming
Okay my temper is taking a turn for the worst.
I have a brand new 5995, a recently updated Hpf10.
When I program the endpoints as suggested by Mike I can only get 50 degrees of travel no matter what I do.
The other puzzle is that the manual test will only center, the left and right buttons do not work.
If I reset the servo then you get 180 degrees however the L and R still do not work.
Fail safe is off.
Servo works when I connect it to the reciever but with the limitations as noted.
I tried the same procedure with a 5945 and everything works.
Lastly when I go full travel setting up the epa the programmer reboots.
