RCU Forums - View Single Post - Stuck Solenoid
Old 09-04-2005 | 03:56 PM
Edgar Perez's Avatar
Edgar Perez
My Feedback: (13)
Default RE: Stuck Solenoid
Hi Ed,
I was able to check/reverse the starter o-ring. Will check if noise disappear on next weekend. They seems to be about 1/2 inch diameter or-ring. Is that correct? Will like to have some spares.
The oil thing for the propane solenoid did not work. Next step?. For now I'm using your regulator direct to turbine with no problem.
BTW, do you have some of the kavan glow plug that comes originally with the turbine. Will like to buy some.
Edgar
PD: See you in Superman
