RCU Forums - View Single Post - DF setup, help
Old 09-04-2005 | 05:44 PM
siclick33
Default RE: DF setup, help
DF can use 'fan' pressure or pipe pressure.
If you have the fan pressure fitting I would use that. The inlet for this fitting should be behind the fan, pointing towards the front of the model (i.e. into the fan airflow). The two methods achieve the same aim of pressurising the fuel system.
