G26 problem
Several weeks ago I was flying my G26 powered cub when the engine lost power. It continued to run but would not rev-up. After landing, I inspected the engine, restarted it and took off again. This time the engine died while in flight. Since then the engine has not run right. It will crank, but not rev-up. It seems to be spitting fuel out the carb when the throttle is opened up. I have changed the plug, fuel, the fuel line and filter, disassembled the carb and cleaned it. I did find a little gummy like stuff in the carb. After removing it I thought that I had found the problem, but it still will not run. I does have an electronic igintion...Ralph, any thoughts.
Anyone with any suggustions.
