RE: CG Matrix, a tip-stalling machine??? Help.
LAteral balance was so close to being dead-on that I didn't change anything. I guess I'll just get used to this trait of dropping a wing. I did find that pinning the throttle while I used up elevator will keep it from snapping out. If I recover from a spin then let it drop on it's own then pull out gently it tries to drop a wing. If I recover, then gas it, then pull up, it doens't drop a wing.
Mike
