RCU Forums - View Single Post - Goldberg Matrix
Old 09-06-2005 | 09:48 PM
  #163
lilcap232
My Feedback: (14)
Default RE: Goldberg Matrix
Glad to hear you and yours are okay!! we have refugees pouring into the surrounding Metro area. On my way to work this AM I met about 30 NYPD rescue trucks headed south on I 85 lights and sirens blazing.........
Okay guys I have discovered the ultimate tip on how to glue the horizontal stab in place with EPOXY!!!!! have everything ready and aligned before mixing, once satisfied with the fit and alignment mix about an ounce of 30 minute and use drinking straws to suck the glue up and then blow it into the fuse around all sides of the stab through the hatch for the elevator bell crank system. twisting and turning fuse as it runs down and towards the rear. If done thoroughly you should see it just barely seeping out of joint between stab and fuse. this method allows for almost 100% coverage inside the fuse and also adds to the strength of the stab itself.
JIMMY
