33
Jwc , That is the automatiic oiler for the chain. Tmoth is right just remove it. Make sure when you cut the extra pice off the lower case haft leave the ridge to keep the bearing and seal in place. I have not had any problems with the bearings. ( and I put them through alot of hard use.. I wounder if the chain oiler would make a easy way to add a smoke system??
