RCU Forums - View Single Post - Official GP Reflection Build Thread!
Old 09-07-2005 | 08:44 AM
  #54
jatkiss
Default RE: Official GP Reflection Build Thread!
Ok that makes sense. That is what I did on the bottom ailerons ( without it sitting in front of me...at least I think that is what I did). What I noticed about the other control horn's (the ones not in the picture), is that they were a little long for the slot...do you just push it in further and cut into the foam a bit? It really did hang out quite a ways (like 1/4") from the back of the wing.
Ohh one more question. You know the pieces that the diag. carbon rods go through to hold the shape of the wings in place (they hold the rods that are the landing gear). They are the small little spacers with the holes in them. Anyway, when I was cutting them off the form, there were only 11 of them (instead of 12). So I put the ones into the wings, and then three of them onto the main fuselage. I have one that is open. My concern is that with tight turns when the plane flexes there could be tearing of the foam...should I worry about this ? Anything I can do as a temporary...or is it something that should be ok ?
Thanks so much for the advice. Of course I didn't choose an easy build for the first one =- ). Sure have learned a TON though...can't wait to try flying it.
Thanks again everyone !!
- Jeff
